97 FORCE 40 SHIFT PROBLEMS
diegojones
Just Got a brand new powerhead and have replaced. Starts fine but "only" starts in forward which is very exciting. I think the shift rod / linkage is off. What position should square rod be in when I connect the shift cable! :confused: Also power trim is not operating, there is a red wire with plastic end on it, Is this part of trim electrical?
roscoe
Re: 97 FORCE 40 SHIFT PROBLEMS
Don't know about the square rod, will try to look at mine in the daylight and get back to you.<br /><br />You had the lower unit off, right?<br /><br />You problem is probably in the adjustment of the shift shaft, where the two halves are joined with the coupler and jam nut. I believe you need to shorten the length of the shaft by adjusting the coupler and jam nut.
diegojones
IF you look at the motor from prop side, on front right there is a square "shift rod" large that goes across under power head!
roscoe
Sorry, mine is not like this, older, different model.<br />Also, my manual doesn't cover that set up.
diegojones
Thanks for your help, unfortunately my manual doesn't either, Anyone Else!!!!!????????
