97 Mariner 4hp - Where does this piece go?
HeBrokeIt
While I was away, my husband decided to replace the impellor. For some reason he also took the propellor off too along with the gears and the shaft. Two bearings fell out one looks like a small hotdog about 1.5 inches long, the other is bigger around with flat ends (like a pill). I put the "hotdog" back in the end of the shaft. But cant figure out where the "pill" goes. Any ideas? <br />Thanks.
rickdb1boat
Re: 97 Mariner 4hp - Where does this piece go?
Do you have a serial number for the motor??<br /><br />Maybe this pic will help:<br />
HeBrokeIt
Thanks. That did it!!!! Piece #27. It's all back together. Now let's see if it still runs??
andrewkafp
More importantly "Lets see if it" LEAKS..<br /> :eek: <br />Hope you put new seals in the gearcase.
