Moggy23
- Jun 22, 2010
- 24
As being a mechanic, this one has got me thinking.
My 23 Caribbean is fitted with a 5.7 ltr 250 hp Mercrusier,1997 fitted with Mercarb.
Starts easy and the choke stays on for about 15 secs and goes off, running at 1000 rpm.
Bring it back to idle and then it starts to to run rich, so I increase the revs so it doesn't stall and as it warms up, it gets worse.
Once it gets to 160 deg. every thing is fine and not a problem for the rest of the day, idles nice and starts easy, this has only started to happen as winter came around, colder the morning, worst the problem.
Rekitted the carby, cleaned and blew it out with compressed air.
Checked float level to 9 mm as to the Mercruiser service bulletin for spring loaded needle and seat.
Cleaned small holes under carby, in manifold for exhaust recurculation.
Timming is 10 deg and idle mixture set in gear when warm which is about 1.5 turns out
Still the same, so I fitted a air bypass in the pvc line to lean it out untill warmed up, just to keep the plugs clean. this is tempory.
The only thing I can think of is too much moisture, condensation around the idle air bleeds when warming up, that causes a rich mixture, maybe.
I,ve shinned a light down the carby when running and there is no flooding, it's as if fuel is building up or puddling on the floor of the manifold.
Has anyone come across this problem in cold climate of about 5 -10 deg C or 40 - 50 deg F
Thanks Moggy
Thanks Moggy
