dfish77777
- Dec 29, 2003
- 21
Hi all. I definetly have a bad connection to the check engine system inside the tach unit on this 1997 Oceanpro 150 HP, it now stays on with the engine off. I checked for continuity between the sending unit in and the ground at the gauge connector and it showed open, but the check engine light comes on as soon as the gauge is reconnected to power(connector plugged back in). Is this a sealed unit, does anyone work on them, and what are my choices for finding a new one. I've looked around the internet and havn't seen anything yet with the four warning lights built in. Any and all help appreciated.<br />I also didn't realize you can't rev up above 1500 RPM, can someone tell me what the potential damage is from that. And is that only neutral or in gear on the hose as well??<br />Thanks all responses appreciated and welcome,<br /> Don T
