Re: '97 suzuki cutting out
Your right it is efi, the first year was '94 then they simlified efi in '98 and also added new fresh water cooling plus a larger charging system. I took the boat out yesterday but could not repeat condition. The condition did happen twice that first evening but did not actually stall the first time, that time I tried to correct it by pumping fuel bulb but it lost rpm's quicker so I quite.Although bulb felt empty the first two pumps,by the third or forth pump it firmed up but then it really feel on its face.Then engine slowly built rpm's for 5-10 seconds and ran for another half-hour with a slight miss until the condition happened that I originally mentioned.I did check all plugs they were dark but other wise good condition,I
will replace tomorrow.The wires were not showing any fire works the evening it happened.I will also go over all battery connections tomorrow.I do not know if it is revelent or not but the next morning when I cleaned(flushed) engine I did not get good water flow(see post suzuki cooling problems?),although it cooled and ran ok when I took it out today,but that condition was not normal.Thanks for all the imput.
