Re: 98 225 tilt ram seal leaking
you will need the tool to remove the trim caps, remove the wire seal reatiner,if used, remove the seal and the shaft oring,if used. replace the cap oring, seal and shaft oring and reinstall torqueing the cap to spec. memory says its about 80ftlbs.<br /> you can see the parts list on the yamaha parts website.
