Need some help. Putting on my rockers on my 4.3 mercruiser. The problem I am having when I follow the mercruiser service manual it tells me to just put rockers on and tighten to 22 ftlb. The problem I am having when I follow the manual and tightening them down and try to turn the motor over by hand it locks up. The interesting part it only affects one side of the heads. I first thought it was the head so I swapped heads and still doing the same thing only different side. It looks like the valves are kissing the top of the piston.
So now what I am doing is rotating motor and waiting for piston to be on the down stroke then adjusting well that's not working.
If it jumped Timing would only one side be affected? Am I grasping at straws any help would be much appreciated.
