Hey Guys, Need some help here. Iv got this Force 50 hp motor 2 cycle. I checked the compression, #1 is 27 and #2 is 130 psi. Thing runs pretty good. Was just working on timing today and was reading my manual and it suggested to start with a compression test. I have tested this a couple times, to make sure. Same results. This motor did over heat a while back, and had to replace the water pump propellor. Bad Head gasket? It idles a little rough, thats why i was working on it today.
Thanks
Daryl
Thanks
Daryl
