98 60hp 4 stroke Water Pump
Erichbd
1998 60hp suzuki 4 stroke<br /><br />I was pumping low water pressure and the engine was over heating so I changed out the impellor still no joy. I'm still putting out low water pressure out of the weap hole and still running hot. I'm leaning towards the thermostat, any ideas?
Elmer Fudge
Re: 98 60hp 4 stroke Water Pump
Did you get the old impeller out all in one piece? Check for any blockages.T-stats could be stuck,also look out for a faulty poppet valve.
JB
Erich, this is the third time you have posted basically the same question. Please stop.<br /><br />If you want your original post at the top of the list, simply reply to your own post. That will bring it up.
