98 7.4 mpi water pump question
jmarines
I have a 1998 7.4 mpi (0l061405) I'm wanting to replace the water pump that's mounted on the block.. can I pick this up at any parts store locally? If so.. would anyone happen to have the correct part number?
Bt Doctur
Its a Bravo pump
18-3309 impeller, wear plate gaskets
18-3150 pump body, oplate, inpeller ,bolts O rings 46-807151A14
18-36001 complete pump assembled 807151A12
are you talking the water circulation pump or the raw water pump?
Bt Doctur has you covered for the raw water pump
the water circulation pump visually appears similar to the BBC short automotive pump, however it is a marine specific (brass impeller, stainless access cover). if you have heat exchangers, you can use an automotive pump, however the correct marine version is about the same cost.
