hey guys so I recently replaced my fuel pump because I had a problem with it dying under load.
so the other day I tested the fuel pump and realized it wasn’t pumping fuel at all. So I replaced it with a new one.
Go to run the boat today and at first it was running great no stalling no nothing Flying down the river, running nice. But then I started having a Problem. Problem I’m having now is I stopped and had a lot of trouble restarting the motor. It was bogging like before but this time when it would start to stumble I would push the choke key in and it would catch and run fine. I would have to keep priming it with the key switch.
It was not doing this before even if I did push the choke switch in, before It would just bog and die no matter what.
I got it home and took off the fuel lines to the carb and put them in a collection to see how it was flowing . cranked the motor over and the one side of fuel line to carbs was real weak almost as if nothing was coming out at all, the other side was a strong stream. So it’s almost as if it’s not getting fuel to the carbs at all right ? I’m not sure what I should do now I’m kinda stumped.
It can’t be the fuel pump right it’s brand new.
Its a 98 Johnson J90slecm is the serial number. Thanks guys.
