98 EFI 225 Stall
dulie
I have a problem with my motor stalling on acceleration when the temps are low. It will start and idle great, but when I go to accelerate it gets to about 2000 RPMs (nearly on plane) then beeps and stalls. It does not die. It will do this 2 or 3 times then it works fine. This happens after not using it for awhile especially when the outside temp is cool(40-60 degrees) I have checked the fuel bulb and it is not losing prime. It's full of oil and the caps seem tight. If I let the engine warm up for a long period it does not happen, but it's hard to do when you are trying to haul booty when a tournament begins.
Any Ideas?
Thanks in advance, Don
dulie
Re: 98 EFI 225 Stall
Any Ideas???
Do I need to burp the oil tank?
How's it done?
JUSTINTIME
take it to a dealer and ask them to plug it in
sounds like a bad sensor somewhere
dulie
Does the computer store codes on bad sensors?
