98 evinrude 115 starter not engaging
fltwn
model E115SLECM<br /><br />Problem - starter turns over but doesn't engage the flywheel. <br /> - have had starter rebuilt.<br /> - installed new starter relay<br /> - verified cables & batts are good.<br /> - took power directly to starter terminals and still no change - just spinning starter.<br /><br /> Does anyone know anything about this? Please help!! Going nuts here!!.
JB
Re: 98 evinrude 115 starter not engaging
You probably have a gummed up shaft preventing the bendix gear from spiraling up to the flywheel, SoCol. Clean the shaft and lube with a light oil, like sewing machine oil.<br /><br />If that doesn't fix your problem, go to the Engine FAQs and do the "wont start" troubleshooting.<br /><br />Good luck, and let us know what you find. :)
fltwn
Thank you for the advice - which leads me to another question <br /><br />- If I take off the plastic cowl that hides the bendix/starter gears, will I mess up the timing or anything else I should be wary of?
