It is misfiring between 1k & 2k rpms only Runs perfect above and below those ranges. It is also random while in the 1 to 2k rpm. It may go a few minutes running normally then bam it will misfire sometimes to the point it will die. This is while underway in the water.
I have rebuilt the fuel pump and new lines. I wonder if it is electrical. Could the carbs run perfect except within that range. WOT is perfect power is good startup is good Idle is good as long as it is in gear. If I let it idle in neutral it will sometimes miss because it is within the 1 to 2k rpm range.
I have no history on the boat as far as service etc. Looks super clean. It appear to me that the intake manifold has been removed sometime in the past due to paint damage on the bolts.
Looking for some guidance as a starting point. Compression is good engine appears super healthy when running 2500 and above.
