'98 Johnson 25 hp pivot pin screw stripped
renelson
Hi, I've got a huge problem. In the process of putting new seals in my lower unit, I stripped the hole where the pivot pin screws in the side of the LU. It has (had) about a 1/4" of threads in the alum housing and now it's completely stripped.
Any pointers? Is a 1/4" hole depth enough for a helicoil to work? Thanks!
Merry Christmas!
boobie
Re: '98 Johnson 25 hp pivot pin screw stripped
If you cut off the helicoil befoe installing it. Been there.
renelson
So you've stripped that one too? I was pretty ticked at myself. Did it seal good?
boobie
Yes......But take your time installing the helicoil.
renelson
Thanks Boobie. Did you use any sealant around the helicoil? Seems like I should use something...locktite...gasket seal...something....
rpsloan
Tap and dye?
boobie
I've always use a small dab of red loctite around the outer surface of the helicoil.
renelson
Yeah the permanent stuff. Thanks for the help. I'll post when I get it done.
renelson
Got the helicoil in and used red locktite as stated above. I'm glad it came with a bunch of the coils - I used more than half of them before I got it right. First of all, the threaded plastic starter lug (for lack of better term) that came in the kit had to be modified to fit flush against the recessed hole in the LU. I used an old soldering iron to make it more narrow. Secondly, the helicoil had to be shortened so that it properly fit in the shallow hole - took a few tests to get that right. Third, the tang didn't break off properly on the first attempt. Instead of breaking clean off, it took the bottom thread of the helicoil with it into the LU.
Anyway, I finally got it and it worked! Happy new year! :)
boobie
Glad you finally got. I'll bet next time you have to do it, it will be easy. Happy New Year to you too.
