Hey, a couple of months ago, I did a compression check on my outboard. Five cylinders hit at 60 or 65 and the top right cylinder hit at 90. I continued to run the motor through the summer because everyone said it was low compression but they were pretty consistent. The motor has a very slight miss when running at about 4800 rpms but runs fine at wide open throttle. However, the motor does not want to idle at all. While in neutral, the motor will usually choke out and die. Or when you shift it to the first notch it just want run good at all, I have to add just a little throttle past the first notch to keep it running. Anyway, a couple of days ago I decided to get another compression check done. All cylinders hit at 115 and the top right hit at 120, which sounds great to me. Does anyone have any idea what could be the problem and what should I start checking first. One guy said the power pack could be going bad but that will be a $325 guess so I didn't really want to try that just yet. Also while at idle on the water hose, I can pull the plug wires off one at a time and on two of the cylinders, it doesn't make it idle any different when they're un-plugged. I would greatly appreciate any help or advice.
Thanks
Thanks
