hello all. need help figuring out issues with my mariner. first of all it does'nt do it all the time.can go few trips with no problem.then on other trips can do it couple times or ten times.its when i go to start taking off and i got throttle at full throttle it won't go over about 2000rpm.sometimes i put in neutral and turn motor off then back on and problems gone.sometimes i do everything like wiggleing all harness connections tapping on all sensors and still messing up.then finally after constantly full throttleing it and back to neutral it takes off like normal.when doing this had someone squeezing gas bulb and no difference so dont think it fuel.i have the repair manual and checked the stator , spark boxes, trigger and tps and all check out good.i was wondering if it could be my detonation module or idle stabilizer? need advice. thanks in advance. ted
