'98 Yami S200 Carb Sync, idle adjust, etc
Tucker99
Gents,
Following procedure in manual, timing set by Yam tech in Yorktown where I bought the boat. Got 2-new red marks on the adjusters and not messing with it. Had water in fuel and had to remove carbs for cleaning. Syncing carbs and the book says to adjust throttle lever adjusting screws on the top & bottom carbs. Simple, loosen cw and that syncs them to the middle carb. After that adjust the pilot screws: Stb 1-1/8 turns, port 5/8 turn; Yami tech had them all out 3/4 turn. Can someone confirm 1-1/8 & 5/8 are correct adjustments for this motor? Little confused after that regarding adjusting throttle roller adjusting screw on the middle carb. Shouldn't that be set to completely close throttle plate?? With the idle adjusting screw backed off, all three carbs should be completely closed. Idle is adjusted with the idle adjusting screw correct? Thanks guys!
