!988 507X8Cforce outboard ignition
unclefuzzy63
I just purchased this engine and previous owner said it had been running fine but had lost its spark. I removed the flywheel and removed stator and trigger and checked both for resistance.Found that trigger is low so I have ordered a used one. when removing the wires from the rectifier, I found it had a bad prong so have ordered a used one of them also. When I was removing one of the wires from the rectifier,I dropped a nut and when fishing for the nut I found a wire jumper in the bottom of the housing. Trying to figure out where it might go but cant find a picture of how it is wired. Have just ordered a manual but any help would be appreciated. Thanks Marc
