Captain Jeff
- Jun 15, 2005
- 159
1999 Johnson 115 V4. The drive shaft seals just below the water pump keep wearing out and water leaks into the gearcase. I replaced these once already and in less than a season they were already worn. There also seems to be extra drive shaft wear from contacting the waterpump housing. This is the 2 piece driveshaft. I noticed there is excessive play if you wiggle the drive shaft. I believe this is why the seals go bad so fast. I found another post with a similar problem: http://forums.iboats.com/showthread.php?t=173745
It looks like the drive shaft retainer clip and pin may be worn causing the drive shaft play. Has anyone else had this experience?
Also, it looks like I will need to remove the propshaft and bearing carrier as well as the entire drive shaft in order to replace the retainer clip. Do I need to shim the driveshaft after this procedure?
Thank You
Thank You
