99 115 V4 overheating
rexicon
Just bought an ex Florida Fish and Wildlife boat w/twin 115's on it and did all the due diligence - mechanic checked engines and marine survey.
Unfortunately the mechanics inspection was done on lift and marine survey was done w/a sea trial that didn't allow the vessel to run for more than 10 minutes at cruise speed - sea trial was conducted on a river and surveyor only saw 4 wot runs which lasted a maximum of 2 minutes before back to idle zone.
The long and short of it is that the port engine overheated during (my) maiden voyage.
Symptoms:
- after approx 5 minutes at around 4800rpm overheat beeper sounded - hot light showed on tach - we immediately backed off and ran at idle for 2 minutes
- Ran it back up to 3000 rpm and repeated above
Contra-indications: (if this an appropriate term)
- pee stream still strong at idle and if in neutral engine would cool off
- engine would still cool at higher rpm's in neutral
Where we may have messed up:
- ran engine 3 times at cruise rpm to get on plane while trying to get home w/no warning buzzer but high temps indicated on temp gauge
- ran engine at lower rpm than its twin in effort to get home but did not let engine hit buzzer before giving up
- basically ran engine while it was overheating w/a mindful eye on temp gauge
Questions:
What is the problem?
Did we FUBAR the engine by running it after the initial warning buzzer?
After maiden oddyssey we trailered the vessel 10 minutes, flushed the engines and the port motor started first crank and pee-trail was still strong.
Any input welcome,
thanks, Rex
tashasdaddy
Re: 99 115 V4 overheating
pee stream does not mean the thermostats are opening to cool the motor. it just means the impeller is pumping. check your compression, before anything else.
qflex1115
i would pull out your thermostats and check your poppet valves(wich should open after 2000 rpms to push more water through). also check the trim and the engine hieght. seems like when u get on plane ur pickups might be out of the water.
Chris1956
OK, Check compression to rule out engine damage. Compression should be 100PSI+ and within 10%.
Next change thermostats or test them for proper operation. They should open at 140*F
Replace waterpump impeller to restore cooling. Retest motor. If still overheat, post back.
