Desertson1410
- May 22, 2016
- 17
I need help i have no spark on my 99 bayliner with a 3.0 mercruiser. So let me start on how this all started. I was changing my oil pressure sender and grounded it out with the starter slave solenoid dumb move I forgot to disconnect the battery. So i lost all power the 50 amp fuse blew out so replaced it. after that the starter slave solenoid would click but starter would'nt turn over so I fried the starter solenoid, replaced the starter,boat turns over but wont start so i changed the ignition coil with no success. took all the spark plugs off cleaned them to see if there was a change maybe some fuel or black build up... nothing. i have tested the slave solenoid voltage, performed the test checked the ignition switch it was good i have 12.3 volts at the starter and at the slave solenoid i even tried disconnecting the grey wire to the tach because i read that it might ground out. I cant seem to figure this out can some one please point me in a good direction
