'99 50 hp 4 stroke Merc dumping fuel from the fuel pump
jigngrub
Was checking my engine out today after the resto so I could go out tomorrow and found a fuel leak.
Every time I squeeze the primer bulb fuel squirts out of this black box on the back of the engine.
It's where the main fuel line connects and 2 other fuel lines feed the 4 carbs, I'm guessing it's the fuel pump? I tightened up the 4 screws on the metal cover but that didn't help, so I figure I need to replace it?
Do I need any special tools for this job, any special procedures? Since I've never done this before should I just take it to my mechanic?
Any and all help greatly appreciated.
Faztbullet
Re: '99 50 hp 4 stroke Merc dumping fuel under the cowl.
Where are the correct fuel ties??? Have you had the pump off? Over-tightening can cause the chamber body to crack which is not sold,you have to buy the complete pump if cracked.
jigngrub
If I knew where the correct fuel ties were I probably wouldn't have even posted this question. I suspect the correct fuel ties were taken off and not properly replaced by an idiot that called himself a professional mechanic (and worked for a national chain marine repair shop) and ripped me off for a $600 on a carb rebuild job a few years back... and I guess my good mechanic didn't notice they were gone when he vacuum synchronized my carbs like the idiot should have done.
I have never touched the pump before today. I don't think I overtightened anything, but I may have.
How much does a new pump cost?
jigngrub
Well it looks like I'm going to try a partial rebuild because my marine dealer doesn't have one of these pumps in stock mainly, and secondly the thing is $167. I think I can get by with $41 in parts.
I'm going to replace the cover which has the gasket I suspect is leaking, the rear diaphragm, and the 2 check valves. If it works that's great, if not I'll buy a new pump and bite the bullet.
I'll also be installing the correct fuel ties.:facepalm:
jigngrub
Uhh... thanks for the help everyone.:rolleyes:
Not too much help here for fuel pumps eh?... but that's ok, I fingered it out myself.
My parts still haven't come in yet, but I decided to take the pump off and have a look see and do kind of a dry run.
As soon as I took the cover off I saw what my problem was.
The diaphragm directly underneath the cover had shrunk/slipped and wasn't being held in place by the cover gasket causing a gaping hole and fuel to leak out and air to be sucked in. I have this part on order, and it's $11.
dunc333
good post dude your lucky over there, in aus they stopped selling pump parts (kits) and you have to buy the whole pump assembly now ,just another merc rippoff""""""""""""
