1999 70hp Evinrude 4stroke (Suzuiki built) with engine turned off and water ear muffs on and water pressure, I pulled the dip stick and got a steady stream of water/oil mixture out the stick. I pulled the plugs and got no water out of the head. The stream continued until I shut down the water pressure. I'm wondering if there is a specific water jacket/gasket I should concentrate on. I will add also no history of overheating, new thermostat and impeller last season.
