ANTI-
- Feb 2, 2018
- 7
This fall I took my lower unit off to replace my water pump. Upon doing such I noticed the oil seal around the gear shifter looked like it might be leaking and decided to change it. Well while changing it, I accidentally pulled up on the gear shift rod and could not get it back down. I assume the clutch dog sprang forward in the housing. I took the lower unit to a marine mechanic who got it down for 420 dollars. I took the lower unit home and installed it. The motor ran good and I saw no problem except my reverse on my controls is forward and my forward is reverse. Also like this WOT doesn't seem to go quite as fast. Is there a simple fix for this? Is so, what? Should I return to the marine mechanic....I prefer not to, its a drive. Any help appreciated.
Thank You
Anti-
Thank You
Anti-
