i did a search first but didn't see anything specific.I don't see this code in the Service Manual. When I turn on the switch I get a check engine light code of 2 shorts - pause - 5 shorts - 5 shorts - and continuation of 5 shorts The engine i can get it up to 3500 rpm but it cuts out to 3000 rpm if i can get up on a plane i'll be lucky to hit 20 mph below 3000 rpm seems to run fine (except for the initial long beep because the check engine light is on).Can anyone shed some light on what the problem might be?Thanks in advance
