99 Evinrude 175 Ficht spark problem.
johnny5o
I'm having trouble getting the engine started. When I check for spark I get no spark sometimes and other times I get intermittent spark. I have checked multiple cylinders with the same results. I just sent the computer out to be checked and it checked good. When I am showing intermittent spark the engine tries to fire otherwise nothing.
johnny5o
I am having trouble finding one. The only ones I can find are the used ones on ebay.
Faztbullet
johnny5o
Ok I replaced the Capacitor and the crank position sensor. It still doesn't start, but it does try to hit once or twice sometimes. Its reading very intermittent rpm on the tach when cranking over. My next guess is the stator.
Crosbyman
before spending $$$$ on parts why not do a complete overall of electrical connection points. Any critical connection point with corrosion could drive you nuts
I see that engine has a power dist panel PDP known to have a history bad (cold) solder spots on the main power input at the bottom causing intermittents.
BTW... does PTT go out also ?? see diagram or do searches on PDP
issues
at the very least do some voltage checks while it is dead (no sparks)
check power entry at C&D and exit at a B cold solder spot can be resoldered by removing the PDP and resoldering the contact pins C or D
try wiggling -prodding the electricals to see if it wakes up suddenly
Crosbyman
see old search btw please post engine model #
