I have a 99 Force 120HP giving me start up trouble. I took the boat out last week and didn't realize that I had the kill switch off. Continued cranking until the motor sounded as though the batteries died.
Took the batteries to have tested and they were fully charged. Took the lid off the motor and the starter gear sticks when it hits the flywheel when i turn the ignition. I did manage to spray with WD40 and got it to work. Or at least i thought. The other day i took it out and it took me like 8 tries to get the motor to kick over. Seems the starter once engage with the flywheel has are hard time kicking it over. Any suggestions or ideas on this. It does eventually kick, but i though after one or two tries it should work.
Side note, once the engine is ran for a bit and is heated up i have no issues restarting the motor. Starts right on contact.
