After disconnecting the shift rod under the cowling/carb & starter (what a pain), I removed the four 9/16-head bolts, the concealed single long bolt at the back of the section that's next to the tab - as well as the smaller, more recessed bolt next to it. That's 6 bolts in all, and a disconnected shift rod.
I can get the rearmost section to split about 1/8", but can't for the life of me get the front section to split enough to get a screwdriver in the gap to pry.
It's like I'm overlooking a bolt in the front somewhere.
What am I missing? Can it be that corroded in a guide pin?
Did it need to have been in neutral before disconnecting the shift rod and trying to split the sections? I know in order to drop the lower unit on an Alpha One, you need to be in neutral or reverse(?).
Is it just a matter of a corroded sleeve or guide pin, and if so, what are the tricks to break this corrosion free?
Thanks!
Thanks!
