Re: 99 Merc 25HP impeller issue
Hi Cliff,
This motor is new to me, so this is the first experience with the muffs. So far I am not impressed with the muff.
Here is a link to the gear case components
http://www.**********/parts/search/Merc2/Mercury/25%2C%2025%20SEA%20PRO%2C%20SUPER%2015%20%282%20CYL.%29/0G760300%20THRU%200T979999/Gear%20Housing%28Driveshaft%29%20%282.25%3A1%20Gear%20Ratio%29/parts.html , they do not show a kit.
When I got a spare impeller for my motor (I did not need to replace), the dealer also had a kit, but he was so inept, that I am surprised that he got the impeller right!
Depending on the pump housing, the water might not get through the pump if the motor is not running. So I would not trust that test. You could test the flow across the block by removing the water pipe from the pump (when the leg is off), sticking it up into the block, rigging up some coupling with the water hose, and seeing if the water gets through. I did not do that test, probably I should have. But in any event, I will try my motor in a barrel or in the water next time.
Were you missing pieces of the impeller, is that why you think you might have bits and pieces in the block blocking water passages?
Regards, Peter
