99 Mercruiser 5.7 stalling at low rpm's
David Inch
Boat runs great at speeds. After the engine is warm and either stop or try to get into reverse the engine stalls out. When I restart the only way to keep her running is to rev the motor.<br />Any ideas?
novicetech
Re: 99 Mercruiser 5.7 stalling at low rpm's
When was the last tuneup? Do you have a manual? Also sounds like shift cable could be going.
David Inch
Probably does need a tuneup. No manual with the boat. Boat seems to shift fine just does not maintain the idle.
