99' Mercury 90hp 4 stroke oil leak
thcarson
Noticed a small pool of oil after last use. The oil appears to be originating from the drive shaft housing when motor is trimmed up, anyone know if this is a seal problem? Also if someone knows what the piece on the motor that the steering rod link bolts to is called? Mine is corroded and would like to replace.
Thanks,
Kit
