99 model 6 hp. johnson cranking problem.
chodie
99 model 6 hp. cranking problem. Have checked spark at plugs and they will fire and looks ok. Gas is getting to carb. Installed new fuel pump and rebuilt carb. Still will not hit a lick. Checked plugs after trying to crank and no fuel is getting to them. Why? Would appreciate help!!
tashasdaddy
Re: 99 model 6 hp. johnson cranking problem.
most likely, stuck float needle valve in the carb, not allowing fuel into the carb itself. or clogged fuel jets in carb.
JB
Engine FAQs. "Outboard won't start".
