99 Trollingmotor problem Evinrude
fishfighter
I purchased a Evinrude trolling motor with the foot control (1999 model) on ebay. Yes Evinrude.... weird but it matched my outboard. My problem is that the prop is not the one that was made for it. the previous owner rigged a "weedlesswedge" to fit it by deepening the mounting hole to allow the threaded pin to go far enough to get the nut on to it. I have searched but not been able to find the proper blade for this motor. I am aware that walmart sells 2 different models of the weedlesswedge and I have not checked the larger sized one to see if it fits. The model number is:HBF26 99 thanks for any help.
rickdb1boat
Re: 99 Trollingmotor problem Evinrude
You can get the original prop here:<br /><br /> web page<br /><br />BTW... I have the same Evinrude troller. The prop that will fit yours is #116063....
JB
To trollers.
fishfighter
thanks for the information. do you know the thrust lbs of the motor? thanks a bunch
fishfighter
WOW I WOULD HAVE THOUGHT IT WOULD HAVE BEEN STRONGER BUT THAT IS JUST PERFECT FOR MY 14'VHULL Oops thanks for the help Rick!
