99 yahama gp1200 shows no signs of power
sbittner
im buying my sisters 99 yahama gp1200 and it shows no sings of power what so ever. i put a battery in it and it acts like is still doesnt have a battery in it. the gauges wont turn on or anything but the battery is showing a full charge and works in another ski. any ideas on what the problem might be?
smclear
Re: 99 yahama gp1200 shows no signs of power
I hate electrical problems. I assume you have the safety lanyard attached.
Here are schematics for your system - there is an electrical 1 and an electrical 2 check both
Rivamotorsports.com's 1999 Yamaha PWC GP 1200 X Parts List
Here is the service manual
http://www.cajundude.com/GP1200R Service Manual.pdf
The only thing I can suggest is to check each component. If no one here can provide more help, and you can't find what you need with the links I provided, you might try posting your question here;
GreenHulk Personal Watercraft Performance Forums
CJ River Rider
Before you do above, wire brush the wire terminals which connect to the battery. This is a common problem on old GP's, I learned this the hard way.
pinbodean
Yamahas have a security system on them. They will act very dead until you enter the code. If you haven't found out yet, you need to press the "A" on the gauge 4 times. It will then say start, and it will crank. I hope this is the problem.
WaterDR
Fuse?
