a few days ago i was checking my max RPM and speed, while i was doing so, reached 5000RPM, suddenly the gear started gradually slipping into neutral, if i pull the throttle back it went back to normal
then i tried again and it ran fine for about 30 seconds and then it started slipping into neutral again
when got back from fishing i tried it once more, and the same thing happened on even 4000RPM
i searched the internet for answers and noticed the most common problem for these symptoms is a spun hub
so i decided to start working on pulling it out
was a real ***** to do so but after buying a puller and modified it a bit ive managed to pull it out
as i was pulling it out, there was like pieces of plastic which looked like it grinded in there into powder falling down from the back of the prop
and when i pulled it out, i wasnt thinking and didnt take a photo of it so il try to draw something on an existing photo i found on the internet to describe better what i saw
came out a little exagarated but i hope you get the picture
now could this cause the gear slips ?
cause the mechanic whos installing a new plastic hub right now said that it most certain should look like that but wasnt so sure thats the reason it was slipping
what do you gents think ?
