Re: A better way???
honestly in 30 years of riding street bikes and more recently atv's with elec start, I have never put any batteries on tenders. Never lost one yet at less than 6 years of age. boat batteries same thing.
with the boat I disconnect the wires, bikes and atv's I don't even do that. As long as their at full charge going into winter they seem to be fine coming into spring.
The two good batteries in my travel trailer froze last winter while it was set up, unattended in an RV park. Vowing not to let that happen again to the 2 new Interstate batteries, and wanting to get the most lifespan out of them, I recently read up some on battery care. Allowing a lead acid type to sit and lose its charge over a winter, or even more than a month, cuts it's lifespan. What I found was that fully charging every two weeks, or at the VERY least once a month, helps to get the longest life from lead acid batteries. Or, use a battery maintainer, as being discussed here. In my trailer, there is a battery cut-off switch. Pull it out, and the batteries get charged. I do that every 2-3 weeks, then push it in/off (it's a 2003 - I don't think it's a "smart" charger). For the boat, I'm using a maintainer when it sits unused longer than 2 or 3 weeks. And before each use, I fully charge up the batteries.
A battery maintainer will fully charge a battery if its down some, say after a lot of cranking, but it takes a whole day or two to do it.
Interstate claims their polypropylene cases are better at insulating the batteries from unwanted discharging to say, a concrete floor, than the old hard rubber cases. That was a major problem in the past, but I also still put my stored batteries on linoleum or wood, not directly on concrete. Also from Interstate: a stored battery will lose 4% to 8% of its charge a month, possibly more if it's not clean between the terminals. If the case is dirty, the terminals probably will be "talking" to eachother. So keep those cases clean, both in use, and in storage.
