a boat
liusigou
this afternoon I went and checked a boat, year is 1998 and Mercruiser 3.0L. He started the motor without water and then stopped the engine. The cylinder pressure are 130,125,120,120. The engine oil is brand new. Also I found that the motor seemed not run smoothly while pressure testing when he turned the key. my current boat is smooth when I turn the key. Also he does not like to do the water testing because it has been winterization. should I continue? what does the owner want to hide?
the owner mentioned that cabuerator is needed to be cleaned.
matt167
The block could be cracked and he knows something. It’s 2 drains on a 3.0l
liusigou
You are right. I will not buy it without run it in the water. I think the oil will be milky after it running in the water if block is cracked
Scott06
Yeah when I sold a good working boat, add said everything worked willing to water test. As mentioned 2.5/.3.0 are easiest to drain. Needs a carb rebuild means it doesn’t run well. Compression is not great wonder if done after it is hot it will be higher.
when selling a boat I would not water test with out a deal and seeing the money, but if so he should do a water test…if he was buying vs selling he would want that too. Otherwise without water test drop the offer significantly .
RaceCarRich
So he ran it without a hose and muffs? 😬
Ruined impeller definitely. Possibly overheated exhaust shutters. Possible crack looking to hide.
Run…
cyclops222
Keep looking for a perfect engine. Otherwise
You are just giving your money to lying strangers.
Your choice.
liusigou
Your choice.
you are right. I insisted on the water testing. He said OT has been winterization. but the boat was sold at the second day
