First:
Has anyone ever converted a back-to-back seating arrangement to captain's chairs? My engine cover is rotted (the wood frame) and needs to be replaced, so I thought I would convert it into a straight cover and a full bench infront of it.
This would obviously cut into space rather severely, so I'd like to chuck my ugly, faded, torn, back-to-back seats in favor of a height adjustable, swiveling captain's chair for the helm, and a non-adjustable swiveling chair for the passenger side. Before, I used to sit ON TOP of the seat while pulling a tube to see infront/behind me. Some smart tabs would help, but, I'd like to be able to adjust the seat up.
Anyhow, what needs to be done to the floor/support structure to be able to hold the base of the chair? The last thing I want is my chair ripping out of the floor. Also, I'm a big guy (265).
The plywood you see is new and covers the gas tank. The carpet needs to be pulled/replaced anyhow, so I'm not worried about that. Also, I think I may TRY to re-do the floor while I'm down there. Below is a picture.
Second question:
What compound should I use to seal up/cover some of the gouges/scratches in the front of the boat? The PO used the boat in the Missouri river a lot and as a result, it got fairly banged up.
Third Question:
What is this piece? It looks like a ground of some sort for the fuel lines? It's all sorts of corroded and I'd like to replace it.
Thanks for helping a noobie boat owner out. And yes, I started with a project boat
Second question:
Third Question:
