f_inscreenname
- Aug 23, 2001
- 2,591
A follow up question to the post running in cool temps.<br />How do you trust you got all the water out? I have a raw water pump on the front of the motor. It wont drain by engine drains. Then there is the water pump on the front of the motor (same as a auto). That wont drain by the block drains. Then there is exhaust elbows, hoses, shut off valves ........ How do you know you got all the water out? I would love to run on Christmas day but after last year... I winterized with antifreeze. When I closed off the valve to the water pick up in the bottom of the boat (so antifreeze wouldn't leak on the driveway all winter) just a tiny bit off plain water got trapped inside the valve and split it down the middle. How are you sure??? Just a little bit in the wrong place and you done for longer then just the winter. Help me out here.
