a little help needed
clasavi
I have a 1998 mercuries 350 EFI MPI
Engine Serial OL067176
Sterndrive OL153367
I have installed two batteries using a blue sea ACR and switch (position Off, one and combined). I have the house hooked to the deep cell battery (numb. 2) and I have a starting battery hooked up to crank the boat (numb. 1).
assuming I have done everything correctly, my first question is as follow:
1) why does the stereo cut off for a few seconds when I turn the ignition key to start the boat?
to elaborate more, there are 3 wires hooked up to the starter. I have only the largest wire going to the switch number "one" post. the other two wires (red size 8 and yellow/red stripe) go to the breaker.
2) should I have spliced the red and yellow/red stripe wire from (starter to the breaker) and hook them up to the switch number "two" post?
3) Am I over thinking it?
any help will be greatly appreciated
Claudio
Don S
Re: a little help needed
This should explain why it's happening.
Overcoming Dropout of House Electronics during Engine Starting - Blue Sea Systems
That is fine, don't mess with any wires on the starter.
NO!
Hard to say, but you are thinking about it wrong.
Assuming you are using the add-a-battery ACR, just come from the center isolation terminal of the ACR with a 16ga. wire with a 2A fuse and hook it to the slave starter solenoid. The large terminal with the yellow red wire on it. (B in the drawing below)
attachment.php
clasavi
I ran the 16ga wire from the SI terminal to the yellow/red stripe located at the engine start switch. is that ok?
Ayuh,... That oughta work, that's the other end of the same wire,...
