A lot of smoke
NFarthing
I have a Johno 175 and i start it about once a week in the back yard, it seems to blow a lot of smoke until its warm is this normal.
roscoe
Re: A lot of smoke
Just curious, Why do you start it once a week in the back yard?
NFarthing
Re: A lot of smoke
Roscoe i like to kep the battery charged and saves me winterising the maotor
Robalo
Re: A lot of smoke
I have a 1993 150 merc and I have the same problem. It has the oil injection on it. I hope its normal I tell everyone if it smokeing it getting oil....and its not fouling plugs..
andrewkafp
Re: A lot of smoke
Herty<br /><br />I use the same technique and start mine every couple of weeks. Where I live, it doesn't get real cold (No Winterizing) but I like to keep it lubricated inside and run fresh fuel through the carbs to avoid gumming up.<br />Mine blows dark (petrol) smoke and chokes up the carport, but settles down after a while. You are only supposed to run them @1200rpm on the muffs so you not really blowing the cobwebs out.<br />Plus, the engine doesn't seem to have the same resistance as it does in the water, so it idles like a Harley. But in the water it's much quieter.<br />Note**** Buy yourself an inexpensive low amp battery charger to keep your battery up. The periodic running at idle will take more out of your battery to crank, than it will put back. The Outboards only have a low trickle charge.
Solittle
Re: A lot of smoke
As Andy mentions the biggest benefit is keeping the carbs crud free.<br /><br />I have been hanging around here for over a year and I'd guess that %20-30 of the motor problems are crud in the carbs related.
