A pic of a 1975 165 outdrive??
luva63
Does anyone have a close up pic of their 1975 mercruiser 165 hp outdrive? I'm thinking mine has been swapped out at some time.
Ayuh,... Photo Id of the Alpha series is in Don's Adults Only section at the top of this forum,.....
thumpar
Looks like it might be newer. What are the serial numbers on the drive and transom? That is the best way to tell.
luva63
tanks bondo, appreciate it. Looks like some swappin' been goin' on, thumpar. Serial #6908686 puts it in the 1983-90 alpha 1,R,MR range.
achris
More fish than mountain goat
What you have there is pre '76 transom housing, a 1985 drive shaft housing (top half of the drive) and a gear housing (lower half of the drive) from between 1975 and 1982). Given that the you're saying 1975 in the title leads me to think the transom housing and the gear housing are original, just the drive shaft housing has been replaced at some stage. And that's not a bad thing. The MR drive shaft housings had the stronger gearset. And as it's already stamped with the ratio (1.65) that then leads me to think it was a second hand replacement, not a housing built up....
Chris....
luva63
Thanks Chris, I'm glad it's been upgraded if it's got a stronger set of gears. I'd like to know the style of the 1975 decals on the sides of the upper gear to try to keep the outdrive kinda period correct looking for the '75 boat. jim
ziggy
here's the sticker on the side of my '75 165. as far as i know, mines still an intact mc-1.
the other sticker i got is the one on the gimble housing.
hope that helps.
luva63
Thanks ziggy, I was kinda hoping those were correct for a '75,but wanted to be sure. I'm going to look for those decals. Great looking boat!
