A tale of woe and poor anchor management.
bakerjw
TLDR. A person who should not own a boat wrapped their anchor in their outboard, almost risked certain death and gave me stink eye for taking a picture of his idiocy after we saved them.
A couple of years ago, my son and I were down in Snead's Ferry staying on the new river. On this particular day, we went out the inlet but it was a little rougher than we felt like fishing, so we anchored at the "S" turn back in the intlet and bottom fished. See red arrow.
The tide was going out and we heard a boat blow a horn 1 time. Then a minute later again. I mentioned to my son that 4 times means distress. Sure as heck, they then blew it 3 times.
Annoyed but doing the right thing, we pulled up gear and anchor and went to see if we could help. When we get there the guy with his less than thrilled son, explained that he got his anchor caught in the prop. They were right off of North Topsail with an outgoing tide. He said that they were thinking about bailing out and swimming to shore.
Anyone who knows the New River inlet knows that swimming in an outgoing current goes from being a rescue to a recovery in minutes.
So, no life jackets in view. No marine radio. He hadn't even called the CG when he realized they were in trouble.
I tied off my anchor line and tossed it to him and he proceeds to start pulling his boat towards us. NO. Just stay in your boat, use the OB as a rudder and I will pull you to someplace to untangle the anchor rope. The current on the Topsail side was FAST as expected, so I idled up onto the sandbar and set my anchor before gradually releasing the line to him. When they were set, it was about 3' of water. I told him to get out and untangle it.
It wouldn't budge. I asked if it was in neutral. Nope. Once his kid put it into neutral, it came right out.
NOTE. It was not just rope and chain. It was the actual anchor wedged in there. I could not resist a pic and got Stink Eye in return for dropping everything and helping someone who should not have a boat in the first place. He said that he didn't have his wallet so couldn't pay me to which I replied "Get a marine radio!"
Grub54891
Cudos to you for helping on what could have been a bad situation. I towed in a boat that I saw the guy paddling with a canoe paddle, his engine died, but at least it was on a calm lake. Turned out it was the same guy that rescued me the winter before, I slid off the road on some ice and was stuck. We both had a bit of a laugh. One hand feeds the other!
bakerjw
It is. I am chuckling again.
I've gotten an anchor rope on the prop once but never to that extent.
One thing that sucks about the entire situation were all of the other boats that completely ignored the distress call.
due the the current and fluidity of the situation, I ended up with a broken downrigger mount and anchor on the foot. <OUCH>
Mc Tool
Trying to envision a situation where you anchor up in tidal water and end up with the line in the prop?
Maybe got the anchor stuck and was driving around in circles trying to pull it loose .....I dun that lots of times .
dingbat
I guess.
I was taught to point the bow at the anchor, turn the wheel hard over into the current and back down to keep tension on the line at all times
rolmops
Getting the anchor stuck in the prop is not hard when the anchor line is short, drags through the sand and whoever started the boat forgot that he was anchored in the first place
Jeff J
A few years ago I had to go out to an I/O powered ski boat to untangle a ski rope. It wouldn’t just unwrap and had to be cut several times to free the prop. Of course, this had to be done underwater while holding my breath in near zero visibility water. The prop shaft was bent and there was some rope that could not be removed from the mount until the boat was trailered.
When I arrived at the boat I found it beached with the lower unit being used as an anchor so not sure if the shaft was bent because it was being used to hold the boat or by the rope.
dingbat
I can see this happening in a lake with no current, but how does that happen in tidal currents? Current keep the boat down tide of anchor
It looks to me like the anchor rope was on the aft cleat.
Maybe.....very stupid thing to do in a current.
Good way to pull the transom underwater and swamp the boat.
Mc Tool
Yep ,recently in Bluff Harbour ,2 drowned ,2 survivors ( the ones wearing life jackets ).
Had the boat anchored to rear cleat ,anchor stuck and wave comes over transom and down she goes .
Mc Tool
Another possible contributing factor is this buoyant polyprop rope ....and untidy rope management , I mean I have seen peeps doing stuff that just about guarantees a wrapped prop.
