A tip for detaling hard to get to spots on the boat hull.
Old Ironmaker
A tip for getting to those detail areas a knuckle busting scrub brush won't. I searched high and low for a small stiff bristle brush I could put on my cordless drill and couldn't find anything anywhere where I live. So I commandeered a 3" round stiff bristle brush from under the sink that has a screw on top that is supposed to hold a liquid cleaner. I popped the back off and inserted a 3" bolt, nut and washers, I glued the metal together with Gorilla Glue. I masked off the transducers and anything I thought might be susceptible to the my 1 part to 1 part Lysol Toilet Bowl cleaner and Hydrogen Peroxide mix and put it on my cordless drill. Wet area, spray on my Lysol/Hydrogen Peroxide mix with a small chemical sprayer and immediately scrub away then rinse well. Works great for the hard to get to spots like the around the transducers, rear ladder, around livewell inlets and outlets and riveted keel etc. Also that spot under the side rails on the trailer a brush and fingers won't fit.
Dragons Den or Shark Tank maybe?
