So last season I noticed a super slow gear oil leak, I say leak because the reservoir drops about 1/2 after a weekend but I don't see any leaks.
I pressure tested the lower unit, holds it perfectly for hours. I emptied the reservoir and put some air into the hose at the transom but did not see any leaks between the outdrive and reservoir. There was no oily residue in the water throughout the season. The outdrive gasket was brand new.
Any other spot to check?
Thanks
Thanks
