Re: ac delco alt
i have a 3 wire alt that is not doing to well
Not doing so well, as in; howling, not putting out current/voltage, etc.???
I've rebuilt them before and you can get complete rebuild kits with the most common failure items, bearings, electronics, brushes The kits were about $30 last time I got one, though that was probably 10 years ago.
If it's just howling, see if replacing the front bearing solves the problem, the beaing is about $5-10 at your local auto parts or bearing supply store. Regrease the rear needle bearing while you have it apart.
FWIW, you can get a new knock-off (Chinese) Delco marine alt from DBelectrical for $60-70. I have one of the 100 amp alt's and it's been working fine.
