Ac Delco electronic dist timing procedure
jc turtle
I have a 1999 Chevy 350 with AC Delco ignition. I could not find the timing plug so I set the timing to 10 degrees.
I bought the timing plug to set base timing. When I plug in the timing plug, the timing still reads 10 degrees. I thought it would change using the plug. Am I correct or not? Also, if the plug is in, the engine will not start. I have to remove the timing plug so it will start then plug it in. I have not checked the timing at 4000 as the directions say. The 4109 Edelbrock
4v will not get above 3000 rpms. I will post that problem in the carb section. Thank you in advance, John
alldodge
This question needs to be in the OMC section, it is electrical but it more about timing. I know its OMC because your carb thread, but this should have been mentioned here also
GA_Boater
The Delco EST distributor needs to have 12V applied to the plug, along with the 2 other wires connected together to adjust timing
Also the carb and this timing issue should be in the same thread
