ac delco spark plugs vs. autolite ?
rodbolt
Re: ac delco spark plugs vs. autolite ?
yes<br /> one is for counter rotating engines<br />good luck and keep posting
diew
so i can't use autolite spark plugs in my 5.7L chevy engine since i found ac delco ones in there when i took the plugs out?
rodbolt
hahahah<br /> sorry<br /> I was just funnin<br /> either brand will work as long as they are of the correct heat range.<br /> me I like keeping AC in my GM and autolite in the fords and NGK in the yamahas and champion in my OMC. as long as the correct resistor or inductive type plug is used its really of no concern who made it.<br /> good luck and keep posting
diew
I pulled out the ac delco ac-MR43T plugs. Would i be able to put in the Autolite 26 plugs and get the same performance?<br /><br />I can't seem to find the temp ratings for either plugs.<br /><br />thanks
ron7000
Banned
heat range for autolites, acdelcos, champions, and other American plugs get colder as the number goes down. an autolite 24 is colder than a 26. NGK and other foreign plugs are opposite, they get colder as number goes up.<br />I think you want an autolite #24 to cross with an AC-43T.<br /><br /> http://home.att.net/~ngkaz/wsb/html/view.cgi-home.html-.html <br /><br />dnld the ngk cross reference matrix, a 2.0MB excel file, and you can find what you need.<br /><br />some other links you might find useful:<br /> http://www.acdelco.com/html/pi_plugs_ident.htm <br /> http://www.spark-plugs.co.uk/pages/technical/spark_plugs_technical.htm
ron7000
Banned
I have an older version of that cross reference matrix from ngk, which I think is more correct. The one they have up now has been redone, and it doesn't seem to match my old one.<br /><br />This listing seems a little better though<br /> http://www.clubplug.net/cross.html
diew
thanks for the info..Actually, on autolite's website. they say what plug to use for my engine..So i'm now using a 25..hopefully its not too hot.
