Access Hatches
BiggPops
I have a 99' EdgeWater 185cc and am trying to find replacement access hatches to take the place of the old ones. They aren't damaged yet but they are weathered and i would like to keep the boat looking as good as possible. Is there anyone that can make them to my measurments? I'm having a very hard time finding any the same sizes as what i have now. Even anything close to what I have.
Gary H NC
Re: Access Hatches
What type are they? The round screw in or square?
bob johnson
Re: Access Hatches
check out TH-Marine
they have a bunch
as well as a brand called Temptress
they have a bunch
good luck
bob
BiggPops
Re: Access Hatches
The hatches are square and rectangle and i ahave looked all over iboats and found a lot of things i want but not the hatches.
BiggPops
Re: Access Hatches
TH Marine looks like they have one that I am looking for. When I get home i will have to break out the list of measurements and see if they any of the others.
BiggPops
Re: Access Hatches
Thanks Gary and bob! (both bobs) Between these sites i should be able to find what I need.
escapade
Re: Access Hatches
while searching for T-bolts at home depot, they have access hatches in the plumbing department, they were under ten dollars, they are normally used for hiding shut off valves but might work in your case, also they have a rubber seal around the edges.
